March 18, 2024 at 2:46 pm
christian.scheffler
SubscriberHi all,
I encounter problems that breakpoints are often not working in Scripting Discovery (2023R1, 2024R1).
The debugger does not stop and therefore a stepwise debugging is not possible.
Is this a known problem?Best regards,
Christian -
March 19, 2024 at 12:20 pm
Atharv Joshi
Forum ModeratorHi Christian,Â
Let me check this and get back to you.Â
Thanks and Regards
Atharv -
March 19, 2024 at 12:31 pm
March 19, 2024 at 12:53 pm
christian.scheffler
Subscriber -
March 19, 2024 at 1:21 pm
Atharv Joshi
Forum ModeratorThanks Christian, I am looking into the support case.
Regards
Atharv -
March 25, 2024 at 10:13 am
christian.scheffler
SubscriberHi Atharv, the debugger has been working as it should for the last few days without any changes. No problem with breakpoint stops. Nevertheless we installed SP2 now and will monitor the problem if it appears again.
Thanks for checking. This topic can be closed.
Christian -
March 26, 2024 at 6:56 am
Atharv Joshi
Thanks for the update. Glad that its working with the Service Pack. ÂÂRegardsAtharvÂ
Viewing 6 reply threads
- The topic ‘Breakpoints Discovery Scripting’ is closed to new replies.
1311
