LS Dyna
LS Dyna
Brace members penetrating into legs
    • ArchEng
      Once the simulation completes, i see that the braces that are in close proximity to the impact zone are detaching and penetrating the leg and wobbling around? The penetration doesnt produce any local strains in the leg either. Is this normal? If not, What am i doing wrong? How do i resolve this?
  • ArchEng
    Found the problem.
    The geometry was faulty with significant gaps between the brace and the leg members. This was preventing the "bonded" contact from keeping the two members glued / welded together as it should have.
    Increased the “maximum offset” of all the members with such problematic contact regions to a value greater than the gap and it works perfectly.
    All members display the welded/bonded behaviour now, as they should.
  • Reno Genest
    Thank you for letting us know that you found a solution. I will close this thread.
    Have a great day!
    Reno.
  • Viewing 2 reply threads
    • The topic ‘Brace members penetrating into legs’ is closed to new replies.
