Electronics
Electronics
“Boundary does not have mesh” ERROR Help
    • bryanluippold
      I am trying to run a thermal simulation using ANSYS Icepak that involves fluid flow between two inlets and outlets. I've imported the geometry and simplified the model to avoid any meshing errors. I've refined the project and attached an image of the mesh. When I try to analyze the solution setup, I get the error "'CPU_Inlet': Boundary does not have mesh." I can visually see the mesh when using the mesh viewer but this error occurs whenever I attempt to model fluid flow in this project. Any help would be appreciated. Thanks.
    • Pdev
      Hi Bryan
      Thanks for reaching out. This might be due to Object priorities. Please ensure the Inlet has a higher priority. If you need further support, please file a case on the customer portal. Thanks!
      Best.
      Pdev
  • The topic ‘“Boundary does not have mesh” ERROR Help’ is closed to new replies.
