December 4, 2023 at 9:46 am
Ghulam Qadir
SubscriberI am simulating a shell and tube type heat exchnager in ansys Fluent. I am simulating external flow around the pipes. I would like to know what should be the inlet velocity for shell side which has cold water at 15 C. Tubes have hot water at 70 C. Please help me with boundary conditions
December 4, 2023 at 10:25 am
SRP
Ansys EmployeeHi,
Specify the inlet velocity based on the flow rate or the desired Reynolds number.
You can check fluent user's guide on modelling heat exchanger: 15.5. Modeling Heat Exchangers (ansys.com)
Hope this helps you.
December 4, 2023 at 10:56 am
Ghulam Qadir
SubscriberWhat would be the ideal value for cold water inlet velocity at shell? I am considering the application of heat exchnager for domesting heating
- The topic ‘Boundary Conditions Shell and Tube type heat exchanger’ is closed to new replies.
