March 8, 2024 at 9:16 pm
Maria Sohail
SubscriberHi,
I am running a simplified model of air as a working fluid flowing over set of 18 cells (modelled as cylinders) to show the transfer of heat from the cells to the working fluid. When simualting the first time, the results were as intended. However, when trying to repeat the results the cell wall boundary specified (308K) does not appear to be read by fluent. Instead it states the model is the same temperature as the atmosphere (298K) and inlet air tempertaure and so no contours of heat trasnfer are shown.Â
If anyone can advise as to why this may be happening, I would really appreciate it!Â
March 13, 2024 at 2:49 pm
Murari Iyengar
Ansys EmployeeHave you checked if all the necessary files and boundary conditions have been set when re-running the case?
March 18, 2024 at 2:21 pm
Maria Sohail
SubscriberHi,Â
Yes, I have double checked the boundary condiditons before re-running. What do you mean by files?Â
Thanks!
- The topic ‘Boundary Conditions not recognised in Thermal Analysis of Battery Module’ is closed to new replies.
- affinity not set
4202
1493
1375
1197
