October 24, 2021 at 10:50 am
zackhyjuan
SubscriberOctober 25, 2021 at 10:09 amRob
Forum ModeratorInternal boundaries are the surfaces between cell zones of the same type (ie they're the surfaces in CAD that transfer to Meshing but don't have a physical presence) or they're the label for the facets that make up the cells in the volume. In most cases you just leave them alone.
October 25, 2021 at 10:46 amzackhyjuan
SubscriberActually, when I apply water flow, simulation shows me that fluid particles pass through these solid objects which are plate and shaft. I can't fix that
October 25, 2021 at 11:05 amRob
Forum ModeratorWhat are those zones set as in the cell conditions?
October 25, 2021 at 2:13 pmzackhyjuan
SubscriberThose are set solid in the cell zone condition. Only the part that I made volume extraction in space claim for representing water is set fluid in cell condition.
October 25, 2021 at 2:29 pmRob
Forum ModeratorIf they're solid then material shouldn't pass through them. If you're not solving for heat transfer you can also suppress those volumes in SpaceClaim (suppress for physics) and that'll save you cell count.
Viewing 5 reply threads- The topic ‘Boundary Condition Settings’ is closed to new replies.
5989
1307
