October 16, 2024 at 11:22 pm
Housermanj
SubscriberI am attempting to simulate the flow of resin through a rectangular porous domain using Ansys Fluent. The flow is driven by a pressure difference, with atmospheric pressure at the inlet and a very low pressure at the outlet. Initially, the velocity throughout the domain is zero. The inlet pressure is set to 101,325 Pa (atmospheric pressure), while the outlet pressure is set to 2 Pa. This pressure gradient initiates the flow through the porous medium.
However, when I specify pressure inlet and pressure outlet boundary conditions, Fluent crashes. I have tried various pressure initializations within the domain, including:
- Atmospheric pressure,
- Exit pressure (2 Pa),
- A linear variation from the inlet to the outlet.
Unfortunately, none of these approaches worked.
Interestingly, when I specify a velocity inlet condition (with the inlet velocity calculated based on Darcy's law), the simulation runs successfully. However, the inlet velocity is not constant in reality, as it should vary based on the pressure gradient. Therefore, I would prefer to model the flow using specified inlet and outlet pressures rather than a constant velocity.
The mesh employed is a Cartesian mesh. Any advice or pointers on how to properly model flows with specified inlet and outlet pressures in Fluent would be greatly appreciated.
October 17, 2024 at 12:29 pm
Forum ModeratorWhat operating pressure did you set? Is this single phase? Â
Note, models with pressure inlet and outlet can be sensitive to the initial condition as mass flow is part of the solution. If you also have porous media the calculation can become more complicated as velocity and pressure become very tightly coupled.Â
October 17, 2024 at 2:38 pm
Housermanj
SubscriberThe operating pressure is set to zero. It is mutliphase (VoF) with 2 phases.Â
October 17, 2024 at 3:29 pm
Forum ModeratorAnd the gas density is? What time step are you using?
October 17, 2024 at 5:37 pm
Housermanj
SubscriberThe density for both fluids are set to constant values. The time step is .05 secs.
October 18, 2024 at 8:45 am
Forum ModeratorSo you have a 1 bar pressure drop over the domain, VOF and fixed density. If you use a very simple dP=0.5 rho v^2 how fast is the liquid going to try and move? How does that relate to the time it'll take to cross one cell (ie a residence time)? What is the resin viscosity?
October 18, 2024 at 2:33 pm
Housermanj
SubscriberBased on the Darcy’s equation, the velocity magnitude comes up to 8.0E-05 m/s. The cells are perfect squares in the flow direction, with side 5.0E-3 m. So, the residence time is approximately 62 seconds.
viscosity is 0.1 Pa.sÂ
October 18, 2024 at 3:06 pm
Forum ModeratorTry patching a layer or two of cells at the inlet with the resin. With a viscosity that high you're potentially seeing a result of the gas density (to find the velocity) and not the liquid.Â
5649
1885
1404
1303
