April 11, 2019 at 8:58 pm
sumykk
SubscriberHi,Â
I want to assign a particular name a surface. Let's assume I have a cube which I want 2 parallel faces as inlet and outlet. when I build a solid cube in SpaceClaim I can't rename the surfaces, actually, there is none. If I detach one surface from solid, the hole solid turns into surfaces and there is no more a solid.
My question is how to assign names to solid's surfaces without turning it into surface.
Bests,
Ali
April 12, 2019 at 11:09 am
April 18, 2019 at 11:17 pm
sumykk
SubscriberThanks Peter,
but I want to rename every surface of a cube independently but they are one body Â
Bests,
April 18, 2019 at 11:57 pm
- The topic ‘Boundary Condition in SpaceClaim’ is closed to new replies.
Ansys Innovation Space
1025
962
859
798
