January 23, 2020 at 3:35 pm
tayyaba.bano
SubscriberHi all,
I need to import the points in design modeler, after importing points I followed the following steps:
1. Concept-lines from points
2. Concept-surface from edges
But when I apply the boundary condition at that surface body, it is not visible although it is selected but later on when I click on the boundary condition (wall) in tree, it doesn't show anything. Usually the boundary becomes green and highlighted but in this case not.
Is there any problem with allotting the boundary condition to surface body?Image is attached
waiting for any kind response.
Regards
Tayyaba
January 23, 2020 at 4:04 pm
Forum ModeratorCheck the options to see if you're highlighting both sides of a face. However, what are you expecting to happen by labelling a surface body when you also have solid bodies?
January 23, 2020 at 7:07 pm
tayyaba.bano
SubscriberThank you very much for your reply, yes I have a solid body and it is obtained by extruding this surface body basically, but when I select faces of the solid body to allot boundary conditions then this face which is shown above (which is actually a surface body)is not highlighted as the other faces of the solid body although it is selected under details of the a specified boundary condition. Moreover, when I get fluent settings this face appears to be hollow and not as solid part.
Regards
Tayyaba -
January 24, 2020 at 1:10 am
peteroznewman
SubscriberTry importing the points along one side as a 3D Curve. You might get a better result since it will be a single edge that extrudes into a single face.
January 24, 2020 at 9:05 am
tayyaba.bano
SubscriberThank you very much for your reply, I have tried it by using 3D curve instead of lines from points, but it is behaving the same in Fluent i.e the edge which is extruded is hollow means this face is not indicating
any boundary condition. Also the tip of the flap is not straight by using curve option as it is in lines as shown above.
Image is attached:
A kind response is needed.
Regards
Tayyaba
January 24, 2020 at 11:08 am
Forum ModeratorIn Fluent we're looking for volumes, and labels attached to faces of that volume. If you've created a surface and labelled that it'll not be seen by Fluent as it's not part of a volume.
The end of that face above is probably straight; it's just the mesh is so coarse it's been faceted.Â
January 30, 2020 at 11:53 am
tayyaba.bano
SubscriberThank you very much for your kind information. There was a problem in having Boolean, and trick is involved by selecting the faces for boundary conditions. The face of the surface body was not selected initially, I suppressed it and only selected the extruded slid body just and then un-suppressed the surface body and it worked. Also I worked with kines from points instead of 3D curve just to have straight edges.
Regards
Tayyaba
- The topic ‘Boundary condition across the Surface body is not visible in design modeler’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
- PlugIn Error: Failed to import assembly from SpaceClaim. The object is deleted.
3024
971
857
809
777
