TAGGED: ansys-maxwell-3d, error, stl, unite-boolean-operation
January 4, 2025 at 6:55 pm
schectma
SubscriberPlease see attached screenshots and advise.
Upon executing the Unite command on all (solid, watertight) objects shown, they disappear and an error is logged to the Message Manager: "Body could not be created for part because of invalid parameters to Unite operation." Version is 2024 R2. Coil object is an imported .stl, while other two [polygonal solids] are native Maxwell 3D geometry.
Very few similar threads exist on this forum:
fail to perform unite boolean opeation and create enclosure using imported SolidWorks CAD Model
Hexagonal polyhedron unite error
Hoping someone here can help. Thanks.
January 13, 2025 at 12:47 pm
NA
Ansys EmployeeDear schectma,Â
The cause of this error is due to the fact that you are trying to unite objects of different material. As I can see from your first screenshot, two objects are vacuum and one is not assigned a material. In order for the boolean function "unite" to work, all of the objects need to have the same material.Â
I hope this helps!
5069
1771
1387
1248
