Bonded contact does not work between shell body and solid body.
    • jeon hyeon min
      I have a problem in static structural.
      I applied Bonded Contact between shell body and solid body, but errors occur.
      When I checked the mode shape, they penetrated each other.
      Let me show pictures below.
      There are two parts. one is shell body(Midsurface) and another is solid body.
      shell body is upper part(with red face).
      I applied bonded contact like below.
      Because the shell body is midsurface, there is gap(thickness/2).
      Both of materials are Structural Steel.
      I tried under procedures.
      1. Program controlled
      2. MPC(radius 1mm ~ 1000mm)
      3. BEAM
      But 1, 2, 3 didn't work like picture below.
      The contact in picture above is contact 4.
      And also I set the variable contactAllowEmpty=1, but it didn't work.
      Another approach was 'Node Merge' between faces, but the result was not what I indeed.
      In this situation, what should I do?
      How can I apply bonded contact to them? Is there any other way:?
    • Govindan Nagappan
      In details of contact region, you can set yes for "shell thickness effect" to account for the gap
      Also increase the pinball radius in details of contact. You can set this to a value larger than the gap
      • jeon hyeon min
        Thank you for your answer!
        I've already changed 'shell thickness effect : ON', but result was same...
        And I increased pinball radius 1mm ~ 1000mm(10 times thickness), but result was same.
        Is there any way?
    • ErKo
      Perhaps this helps:
      https://simutechgroup.com/bonded-contact-between-shell-faces/
      All the best
      Erik
      • jeon hyeon min
        Thank you for your reply!
        I've already read that post in that link, but nothing helpful to me..
  • The topic ‘Bonded contact does not work between shell body and solid body.’ is closed to new replies.
