TAGGED: #mechanical-#workbench, gap, gasket, nonlinear
February 20, 2024 at 12:51 pm
mrivero
SubscriberHello everyone,Â
I am trying modelling compression of a gasket between two plates caused by bolt pretensions. The assembly consist of two external plates bounded by four bolts (simplified modelling by beam connections), between them there are a gasket and a layer which is thinner than the gasket. The objective is compress the assembly to the gasket's thickness will be equal than the layer's thickness.Â
I can not run the simulation because an error message comes up ("The L-2 norm of the residual force overflowed. This may be caused by PRED,ON or birth/dead elements. Please use PRED,OFF and try again.")
I have tried changed the mesh, the contacts, enter the command "PRED,OFF", adjustment... I don't know what to do to solve the problem.ÂÂI'd really appreciate any help.ÂBest regards. -
February 23, 2024 at 11:45 am
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps: Error static structural non linear simulation (ansys.com)
Ashish Khemka
- The topic ‘Bolt pretensions and gasket – nonlinear material model’ is closed to new replies.
3622
1303
1132
1068
1008
