October 9, 2018 at 12:20 pm
tarkanucak
SubscriberHello,
I'm trying to use the option "Body of Influence" for mesh sizing, but I have "Element Size" and "Sphere of Influence" options only. Is BOI not included in student package?
Yanki
October 9, 2018 at 12:25 pm
Naresh Patre
Ansys EmployeeHello Yanki,
The Body of Influence option is available in the Type field if you selected a body and Use Adaptive Sizing is set to No in Global Mesh settings.
October 9, 2018 at 12:26 pm
Karthik Remella
AdministratorHello Yanki,
You should be able to find 'BOI' option when you 'Insert' the 'Sizing' feature in WorkBench Meshing. You will have to select the 'Body' filter. You should be able to see the body of influence feature in type. Here is a screenshot.
Here are some links you might find useful.
https://www.youtube.com/watch?v=3E1p1w32jt0
I hope this helps.
Best Regards,
Karthik
October 9, 2018 at 12:42 pm
tarkanucak
SubscriberThanks for the solution, turned off adaptive sizing and it worked!
- The topic ‘“Body of Influence” for Sizing’ is closed to new replies.
- CONVERTING STL FILE IN TO SOLID
- How do I fix this irregular face meshing problem?
- [ANSYS Meshing] how to activate curvature for a sizing in a script?
- ICEM O grid mesh for sloped pipe
- Meshing Help – I keep getting errors. How would you tackle this geometry?
- what is the best way to apply shear stress to a shell 181 element?
2778
965
841
599
591
