October 14, 2024 at 2:58 pm
Otokemo
SubscriberHello, I'm trying to collide the cylinder (material:water) to the net.
I'm using SPH approach, but the net elements are very thin and they go between the the particles and has no effect on the net geometry.
I also tried Lagrangian approach with Explicit and Ls-Dyna as well.Â
With the Explicit, the water cylinder elements are distorting and I'm getting energy error too big error.
With the Ls-Dyna, the water cylinder doesn't go throu the net, it just kinda bounces back.
Any ideas?
October 15, 2024 at 3:43 pm
Ram Gopisetti
Ansys EmployeeHi Otokemo,Â
Have you used any nodes_to_surface contact between SPH ( MAT_NULL+EOS)and Beams with adjusted penalty factors for contact to be detectable with a very fine particle count ( at least three or more particles covering the beam elements to get collisions) with this approach, you might get something like follows:
I do not suggest to use solid elements here to represent the fluid part, You can try with the solid net elements and see how it goes. Â
Cheers, RamÂ
October 19, 2024 at 6:58 am
Otokemo
SubscriberÂ
Dear Ram, thank you for your reply.Â
I’m using LS-Dyna in from workbench and I can’t find how to apply  nodes_to_surface contact.
Is it only used in standalone LS-Dyna?Also, water2 material from Explicit materials, already has EOS defined, I added MAT_NULL, but which parameters should I use?
Cheers,
Oto
5844
