September 22, 2023 at 11:24 am
Changping Yi
SubscriberHi,
When I observed the information of a cross-section using the section plane in LSPP, sometimes, some blank spots were observed. it seems that some elements at the selected cross-section are gone. I set the scale of displacement as zero. What are the potential causes? Thank you!
Chayir
September 25, 2023 at 3:31 pm
Ram Gopisetti
Ansys EmployeeHi Chayir,
can you check with the newer version of LSPP ?
Cheers, RamÂ
September 27, 2023 at 10:15 am
Changping Yi
SubscriberHi Ram,
  Thank you for your suggestion! I used the lspp4.11. it is the latest version. when I move the section plane 0.1mm, no blanks are at the cross-section.
Best regards,
Chayir
- The topic ‘Blanks in cross sections using the section plane in LSPP’ is closed to new replies.
