3D Design
3D Design
Black window
    • Bruss
      Good evening
      Can somebody help me ? i am trying to do the first tutorial of fluent but the window is not working  it remains black  all the time
      thank you very much for  your support
      Here are discussions on that topic.
      #1
      #2
      #3
      #4
    • seeta gunti
      I hope you are using FLuent default settings so Graphics window is black. You can use workbench defaults, your window colour will change.
      Go to Views --> select workbench defaults.
      Seeta
    • Bruss
      i did it but it does not change the black window
    • seeta gunti
      Can you close the FLUENT and reopen the fluent and select the workbench defaults.
    • Bruss
      I tried but nothing changed
    • seeta gunti
      Better check with graphics drivers. I guess you need to update the drivers.
Viewing 6 reply threads
  • The topic ‘Black window’ is closed to new replies.
