Bingham Fluid – Concentric Rotating Cylinders
    • Marcos Silvestre
      I'm trying to compare the analytical solution of a bingham fluid, laminar in steady state in 2 cases:
      Case 1: External wall rotating 0.5 rad/s and internal wall stationary
      Case 2: Internal wall rotating 0.5 rad/s and external wall stationary
      For case 2 the results are very satisfatory, with a max deviation of 2,04%, Deviation % = (V analytc - V simulate)/V analytc *100
      But using the same parameters for the Case 1 the deviation is around 60%, I've already tried to change the solve method or initial valus but doesnt changed a lot. I will post here the parameters I'm using.
      Here are the parameters I'm using for now in both cases:
      or
      Please can you post an image showing the mesh?
      • Marcos Silvestre
        The max cells I can use is 900k because i’m using the student version, I did the mesh using Gambit.
      The velocity field looks sensible, what shear (viscosity) are you predicting in Fluent?  If you look at a 2d model you can use significantly more mesh.
      I strongly advise switching to either Ansys Meshing (2d, found in Workbench) or Fluent Meshing (3d, use the standalone mode) rather than GAMBIT. Whilst I still like GAMBIT it's not been developed in over 15 years and it's not used in industry (much) any longer.
      • Marcos Silvestre
        The fluid would have the properties of water but with an initial shear stress, so it would be the valor of k=0,001003 (consistente index)
      If you compare the viscosity fields how do they differ?
  • The topic ‘Bingham Fluid – Concentric Rotating Cylinders’ is closed to new replies.
