June 23, 2021 at 8:45 am
mf
Subscriber -
June 23, 2021 at 12:35 pm
Charudatta Bandgar
SubscriberHello MF
If the components are not quantified correctly it is quite possible that they are separate (independent) components. If the geometry is created in SpaceClaim, then copy-pasting it would create the relation where the components will not be identified as separate components. Let me see if it can be done anyway without duplicating the component/ already existing components.
Regards.
July 14, 2021 at 9:24 am
mf
SubscriberCharudatta Bandgar forgot to @ you. sorry for double post.
August 26, 2021 at 8:07 am
mf
SubscriberCharudatta BandgarÂ
Charudatta Bandgar said:
Let me see if it can be done anyway without duplicating the component/ already existing components. Any knews?
July 14, 2021 at 9:04 am
mf
SubscriberHi Charudatta.
Any knews in this case?
I tried out the copy pasta (just to be sure about the relations) but that didnt work sadly.Â
All the best
August 27, 2021 at 4:48 am
Charudatta Bandgar
SubscriberMF Will you be able to send the files? I will check on my end and file a bug ticket in case if even I am facing the issue?
Regards
September 8, 2021 at 7:08 am
mf
SubscriberCharudatta Bandgar Sadly i cant. Anywho ill get back to you if its still a problem within the new update.Â
- The topic ‘Bill of materials’ is closed to new replies.
5899
1306
