Bilinear Isotropic Hardening Values
    • xgteml
      How would one go about finding the needed values for the Yield Strength and Tangent Modulus within the bilinear isotropic hardening to properly simulate the plastic deformation of aluminum alloy?
      Thank you!
    • Sandeep Medikonda
      Please see this post.
    • xgteml
       Thanks for the reply. I am going through a tutorial and they have these values of Yield Strength and Tangent Modulus within the bilinear isotropic hardening portion. Isn't the Yield Strength under that tab just the yield strength of the material? Or is it different? Thanks
       Yes, Yield Strength in the Bilinear Isotropic Hardening material model is just the yield strength of the material.
    • xgteml
      Thank you. When looking at the time plot for equivalent stress, why are there three lines and what does each represent?
      Thank you.
    • xgteml
      Are they along all three axis?
      The three lines are Minimum, Average and Maximum values of Stress. You can turn off the Minimum and Average if you only want to see the Maximum on the Tabular data window.
    • xgteml
      Thank you very much.
    • yashpalsingh7693
      Hello sir,
      How would any one finding the needed values for the Yield Strength and Tangent Modulus within the bi-linear isotropic hardening to properly simulate the plastic deformation of Niti alloy (Nitinol)?
      Thank you
    • Jemuli2021
      I wanted to use the multilinear isotropic hardening of aluminum 1000 series . I could not get the data of plastic stress and strain(experimental data) . Can any one help me with the data?
    • franllorca01
Viewing 10 reply threads
  • The topic ‘Bilinear Isotropic Hardening Values’ is closed to new replies.
