May 11, 2021 at 7:56 am
deb_biswas
SubscriberHello, I am an undergraduate student and I am fairly familiar with the software (FLUENT). I have been trying to do a supersonic simulation on a biconvex airfoil(6%thickness).y
I didn't found the pressure coefficient curve satisfactory. On the right portion of the curve it seems abnormal. I used density based solver with sst kw turbulence model. My meshing and other set up along with cp curve are attached here.
I would appreciate your valuable feedback on this purpose.
May 11, 2021 at 9:30 amRob
Forum ModeratorYou've got a large jump in cell size as you transition between blocks, similarly on the leading edge there looks to be a section where you skew the hex mesh which may tie up with the spike in the lower part of the curve.
December 9, 2022 at 8:02 amdeb_biswas
SubscriberThank you, Mr. Rob. I am really sorry for being so late.
Viewing 2 reply threads- The topic ‘Biconvex airfoil simulation in supersonic flow’ is closed to new replies.
