March 23, 2023 at 12:39 pm
Robert Krobot
SubscriberDear all,
In order to have precise results, I'm trying to figure out the interpolation model of BH curve.When material was defined, relative permeability was defined as non - linear and data set of the measured BH curve was inserted.The BH curve that is used in simulation was interpolated from inserted/measured point.ÂÂIs it posible to find which model/calculation is used for interpolation of the curve?ÂAre there the any documentation where the model is described in detailes?In Maxwell online help document, core losses are described, but I can not find the description of the interpolation model.ÂÂThank you for your time and support.ÂRobert
Viewing 0 reply threads
- The topic ‘BH interpolation curve model in Ansys Maxwell’ is closed to new replies.
