April 14, 2025 at 6:43 pm
scabo
SubscriberHi
I am trying to model 3 phase air, water, solid pipe flow in fluent. What is the best way to model that in fluent. Can i do a VoF modelling of air+water and then add DPM injections? Or are there any better approaches?
thanks
April 15, 2025 at 9:15 am
Forum ModeratorIt depends. The various multiphase models are all "best" depending flow regime and volume fraction.Â
DPM won't see the free surface in VOF, it only sees the cell fluid density & viscosity.Â
April 15, 2025 at 10:34 am
scabo
SubscriberHi, thanks. If i make the pipe periodic in the streamwise direction for the flow, will the DPM particles follow the periodic conditions? or do i have to write UDFs to apply periodic BCs to the DPM particles?
April 15, 2025 at 11:13 am
Forum ModeratorCheck the documentation. However, if the particles are denser than the liquid they may just finish up at the bottom of the pipe.Â
April 15, 2025 at 11:20 am
scabo
SubscriberOkay i will check the docu. even if the particles are denser than liquid it will travel some streamwise distance before settling.
April 15, 2025 at 11:28 am
Forum ModeratorExcept it's periodic - it's already a long way downstream!Â
April 15, 2025 at 11:43 am
scabo
SubscriberYes you are right so we have to model the DPM carefully while using periodic conditions. Cant initialise it with normal conditions. Right?
April 15, 2025 at 12:40 pm
Forum ModeratorYou can, but as you're looking at a very long pipe DPM may not do what you want. Periodic flows have their use, here you may need to model it in full.Â
5649
1885
1404
1303
