March 22, 2024 at 5:49 pm
mert.berkman
SubscriberHi,
I have a gas which may change phase (turn to liquid and vice-versa) in the computational domain. I will be using a Real Gas Property (RGP) table for the material. Which options should I select under Multiphase tab to properly set this model?Â
Thanks
Mert
March 25, 2024 at 10:03 am
Forum ModeratorWhich do you think you should be using? Consider volume fraction and phase dispersion. If you're messing with RGP tables it's not a simple model so initially I may ask more questions than I answer.Â
March 25, 2024 at 3:38 pm
mert.berkman
SubscriberHi Rob,
I'm thinking of using (homogenous) mixture 2-phase model. Does that sound right to you?
Thanks
March 25, 2024 at 3:53 pm
Forum ModeratorPossibly, as I don't know what you're doing it's difficult to say.Â
- The topic ‘Best Multiphase Model for Liquid-Vapor Phase Change (Fluent)’ is closed to new replies.
1885
1403
1298
