August 30, 2023 at 3:50 pm
Jingda Wu
SubscriberI am designing a ring resonator and using MODE to simulate the bending loss and neff. However, I find the result is very inconsistent depending on where the origin is set.Â
In the original simulation of the lumerical example, the simulation center is at x=-0.1um, and a bending radius r=1.5um and here's the result
Then if I set the FDE origin to be x=0 and bending radius r=1.6um, The result is totally different.
This kind of inconsistency continues with user specified bend location. This makes it difficult to simulate complex structures. Is there a reason behind this inconsistency?
August 30, 2023 at 6:32 pm
Guilin Sun
Ansys EmployeeYou are completely correct and it is expected. Please check this article: https://optics.ansys.com/hc/en-us/articles/360034917253-Solving-bent-waveguides-in-FDE-and-FEEM
Basically, it calculates the angular propagation constant and converts it to the linear porpagation constant:
while the angular "beta" is constant, the radius ca be arbirary. Therefore, you will need to correct the result usingÂ
neff1*R1=neff2*R2
then the result will be constant when you change the bent center and bending radius. Please try and let me know if you have question.
August 31, 2023 at 1:52 pm
Jingda Wu
SubscriberI see. Thanks for the clarification.
- The topic ‘bent waveguide problem in MODE’ is closed to new replies.
