July 8, 2020 at 9:35 am
Naief
SubscriberI am beginner in ANSYS, and I would like to find the bending stress in a solid body. In mechanical user`s guide states that to lunsh bending stress object I have to set output controls of "general miscellaneous" option to yes. In addition, the mesh methode must be a thin walled mesh. Could you please help me finding these options. Â
July 8, 2020 at 5:15 pm
peteroznewman
SubscriberDo you want bending stress or the stress due to bending? You can get the latter without any special effort on a solid body.
July 8, 2020 at 8:05 pm
Naief
SubscriberActually I want to calculate the bending stress in a cantilever beam subjected to forces on its top surface.Â
July 9, 2020 at 12:36 pm
peteroznewman
SubscriberIf your cantilever beam has a uniform cross-section, and the forces on the top are uniform across the width, you can use Beam elements on a line body and get bending stress. That is the best way.
July 10, 2020 at 7:44 pm
Naief
SubscriberThanks alot.
July 12, 2020 at 2:35 pm
Naief
SubscriberHi,Â
Actually,I used the Beam elements on line body. I still have the same issue by finding shear stress too. An error says:
For this result, the scoped geometry(s) or named selection should have at least one sheet or a face on sheet or a solid with solid shell mesh.
It is the same issue by finding bending stress on solid body. Is it releated to my Output control setting. ?
July 13, 2020 at 1:25 am
peteroznewman
SubscriberPlease show your results.
July 13, 2020 at 10:33 am
July 13, 2020 at 7:53 pm
peteroznewman
SubscriberAre these Beam Elements?
If so, insert a Beam Tool, and you will have Bending Stress in the folder.
July 14, 2020 at 12:16 am
Naief
SubscriberPeter, I would like to share the ANSYS project with you, so that you can have a look on it. (see attached file above).
First ,Yes, these are Beam Elements. I inserted a beam tool and then I found the following (Maximum Bending stress, and minimum Bending stress). It is fine !!Â
But, why it is not possible to find the Bending and shear stresses if I choose them from (Solution B6) ?
May 11, 2023 at 8:37 am
Mohammad Arif Shahriar
SubscriberI am also facing the same problem. What should be the output control setting for bending stress?
- The topic ‘Bending stress’ is closed to new replies.
3150
1008
945
858
792
