Electronics
Electronics
bending Simulation In HFSS
    • Abdou1
      Hello nin HFSS there is no function to make the bending of, how we can simulate flexible patch , i used the warp function but i get illogical result ?n
    • VivekKamble
      Hi, Warp is the way to make the bend, If you're not getting expected result, I suggest you check port assignment, material or boundary assignment.nThere is another way to bend, you can use any CAD software like SpaceClaim to design your antenna.nThen you can import SpaceClaim geometry into HFSS by using Modeler -> SpaceClaim Link or else you can import geometry file in CAD Format.nHope, this will help.nRegards,nVivekn
  • The topic ‘bending Simulation In HFSS’ is closed to new replies.
