TAGGED: ball-bearing, combin214, modal, stiffness-matrix
July 23, 2021 at 11:32 pm
sanfreece
SubscriberHello all,
I am currently performing a modal analysis where I need to input the stiffness and damping matrix for SKF 7207 ACCBM angular contact ball bearing. The manufacturer refused to help as the bearing is sourced outside of their distributors.
I looked into ROMAC Tilting Pad Bearing program, however, I am not a member.
Any suggestions to calculate the matrix as a function of loading and RPM are much appreciated.
Thank you!
July 29, 2021 at 4:19 pmdlooman
Ansys EmployeeA tilt pad bearing isn't a type of roller bearing so wouldn't have been of much use anyway. Information on roller bearings like the attached paper is available on the internet.
Viewing 1 reply thread- The topic ‘Bearing stiffness and damping matrix COMBI214’ is closed to new replies.
5654
1890
1414
1303
