October 6, 2024 at 3:18 pm
userzff067
Subscriber就是我在用apdl创建悬臂梁的时候用的是beam188单元,圆截面,想输出截面的单元剪切应变EXYEXZ,因为beam188是铁木辛柯梁,所以理论上应该是整根杆的这个值都是定值。现在就是每次算出来都是0,剪切应变都是0.已经开了那个KEYOPT(4) = 2,也有剪切应力,但是剪切应力在截面上值是变动的,理论上截面的剪切应力也得是不变的吧?求给出剪切应变如何设置使得它能输出的方法
October 8, 2024 at 6:52 am
Ashish Khemka
Forum Moderator -
October 8, 2024 at 11:40 am
userzff067
SubscriberNo, I specify that I must use beam188 elements, and the element used in the example you gave is SHELL281. I want to use beam188 elements to obtain the shear strain of the cross section, which is a constant. It can be easily obtained through theory, but I must use the beam188 element of ANSYS to obtain it
October 8, 2024 at 11:45 am
Ashish Khemka
Forum ModeratorMy apologies for the inconvenience. You can try this example: VM2 Input Listing (ansys.com)
Ashish Khemka
- 您必须登录才能回复此主题。
