November 1, 2024 at 4:32 pm
userzff067
Subscriberbeam188单元的剪切系数kykz默认给的是多少?能用命令行修改它吗? 具体的数值感觉是固定的,想知道这个具体值。beam188单元满足铁木辛柯梁,然后这个剪切系数怎么修改?界面上可以修改吗
November 5, 2024 at 7:16 pm
Chris Quan
Ansys EmployeeBEAM188 is suitable for analyzing slender to moderately stubby/thick beam structures.
Yes, it is true that BEAM188 is based on Timoshenko beam theory which includes shear-deformation effects. The element provides options for unrestrained warping and restrained warping of cross-sections.
The transverse-shear distribution calculation ignores the effects of Poisson's ratio. The Poisson's ratio affects the shear-correction factor and shear-stress distribution slightly, and this effect is ignored.
Shear-correction factors for some common sections are as follows: rectangle (5/6), solid circle (9/10), thin-walled hollow circle (1/2). These are fixed values and cannot be changed.
For the arbitrary section (ASEC), shear-correction factors can be input directly using the command SECDATA.
- 您必须登录才能回复此主题。
