December 14, 2021 at 6:48 pm
rhylane.civil
SubscriberHello everyone, I'm using the ANSYS Workbench and i need to model a beam with negligible warping resistance. Could you please kindly guide me on what sort of action should I take to do this?
December 14, 2021 at 8:00 pmpeteroznewman
SubscriberPerhaps you could describe the design requirements more fully.
Please define what you mean by warping.
Why do you want negligible resistance to warping?
December 14, 2021 at 9:10 pmrhylane.civil
SubscriberYes sure sir. I'm trying to study the response of a curved beam which is subjected to the vertical and lateral moving loads. I have analytical solution based on the assumption of that the warping resistance of the beam is neglected (Iw=0) and I would like to compare it with my result from Ansys workbench. I mean by warping, a torsional response of the beam.
December 15, 2021 at 7:49 amErik Kostson
Ansys EmployeeHi
As it says in the hep manual for beam188 (our beam element used in WorkBench Mechanical).
"By default,BEAM188elements assume that the warping of a cross-section is small enough that it can be ignored (KEYOPT(1) = 0)."
BEAM188 (ansys.com)
All the best
Erik
December 15, 2021 at 10:02 amDecember 15, 2021 at 10:39 amDecember 15, 2021 at 10:53 amrhylane.civil
Subscriberreally thank you so much sir for your help.
December 15, 2021 at 11:08 amErik Kostson
Ansys Employeeall the best.
Erik
Viewing 7 reply threads- The topic ‘Beam with negligible warping resistance.’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3862
1414
1220
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
