September 20, 2023 at 7:53 pm
September 21, 2023 at 10:00 am
Sampat Kumar
Ansys EmployeeHi Javat,
Yes, It will change the original extract profile. You can edit the profile individually by saving it into the system and opening it in the new tab. If you tell me the purpose of it, then there might be a possibility that I can suggest a better way to do it or any other workaround.
for more information, you can follow the Ansys help documentation of the Creating a Beam profile
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/spaceclaim/Discovery/user_manual/beamscreateprofile.html
Sampat-
September 21, 2023 at 7:13 pm
javat33489
SubscriberI copy the profile and want to make it a little thicker so that I can use both profiles later. But I can’t do this; when the copied profile changes, the second one also changes. I need to disable this profile dependency between each other. So that I have two different profiles and I can edit each one separately.
September 30, 2023 at 3:30 pm
Sampat Kumar
Ansys EmployeeÂ
Hi Javat,
I haven’t found anything to disable the dependency on the profile. You can only edit the profile and save it to a new file in your system, and then you can use it. There are standard profiles available there, so you can use them if they fulfill your requirements. Â
SampatÂ
- The topic ‘Beam profile dependence’ is closed to new replies.
5694
1891
1419
