August 7, 2023 at 4:43 pm
August 8, 2023 at 1:41 pm
Govindan Nagappan
Ansys EmployeeAre you using Spaceclaim or Design Modeler? Shared topology only works from these CAD sources. You have to import geometry into spaceclaim or DM and make sure share topology is used
Or if you have coincident vertices, use Node merge in Mechanical (right click on Mesh branch) and then merge the nodes with a tolerance to make sure the beams are connected
August 8, 2023 at 4:20 pm
javat33489
SubscriberThanks for your reply. I made a shared topology and increased the shared radius. Everything is working.
- The topic ‘Beam Problems’ is closed to new replies.
1343
1152
