November 18, 2019 at 12:44 pm
salcip
SubscriberHi all,
I am facing a problem while trying to define an I section for beam188 element.
I have designed the structure in pic1.
The lines I indicated have as mesh attributes the I section I defined and I set the option to use orientation KeyPoint.
After I meshed, the structure I obtained is shown in pic2
In pic3 you can see the orientation that Ansys gave to the beams:
As you can see the beam on the left is placed in H shape while the one on the right has a twisted shape.
So I defined the orientation KP of pic4:
I selected the elements in pic5:
and in pic6 I changed the orientation KP:
in pic7 I replot and this is how beams element orientation has changed:
As you can see the beam on the left has a correct orientation (the I shape section is oriented with the thinnest part parallel to the Y global coordinate). On the other side the beam on the right is no more twisted but it is rotated on the Z coordinate.
How can I solve this problem? I want all beam cross-sections oriented parallel to the Y axis.
April 29, 2021 at 2:23 pm
jawad
SubscriberAnyone know the apdl code for change the orientation
- The topic ‘Beam orientation problem’ is closed to new replies.
4818
1587
1386
1242
