August 14, 2020 at 6:51 am
laureng99
SubscriberHello,
The beam elements of a Kelvin cell lattice I created in Spaceclaim are not importing into mechanical- just the base plate surfaces and a singular beam element.
August 15, 2020 at 1:58 pmpeteroznewman
SubscriberDon't post in this discussion, which is a duplicate.nPost in the other discussion linked to below.n/forum/discussion/19545/beam-elements-not-importing-from-spaceclaim-into-ansys-mechanical#latestnAugust 15, 2020 at 6:35 pmlaureng99
SubscriberOk! Not sure how I managed to post twice! I would delete this one if I knew how. nAugust 15, 2020 at 7:14 pmpeteroznewman
SubscriberIt happened to me too. Some posts disappear and go into moderation. Once approved, they reappear. Meanwhile, you think something went wrong the first time you tried to post so you try again and succeed, then later, the approved post appears and now there is two. You can't delete posts anymore, but someone might do some cleanup one day.nViewing 3 reply threads- The topic ‘Beam elements not importing into Ansys mechanical’ is closed to new replies.
4823
1587
1386
1242
