October 21, 2024 at 1:23 am
646247561
SubscriberUsing beam element to simulate rebar, in ls-prepost preprocessing I can see that the cross section of the beam elememt is circular, but after submitting the calculation to ls-dyna, the cross section of the beam element shown in ls-prepost postprocessing becomes a rectangular cross section, is this normal?
October 21, 2024 at 2:31 pm
Alex Rycman
Ansys EmployeeHello,
The information about beam cross section is included only in k-file. Therefore, while post-processing the beam elements on the result files (d3plots) the LS-PrePost will display the beams with the rectangular beam cross section (default). The workaround is to open d3plot and k-file simultaneously (File->Open->LS-DYNA Keyword+D3plot).
Thank you,
Alex -
October 22, 2024 at 12:34 am
646247561
SubscriberThank you, your answer is very helpful!
5664
1890
1419
1304
