beam connection disabled
    • kwak dongkyu
      hi, i want to use beam-bodybody connection function to below image
      but when i tried to use it, it is diabled so i can't use.
      is there any reason for this.
      hinge, rod, box is all different part
    • kwak dongkyu
      from ansys document i think i didn't define the reference point for each body. how can i define it
    • ErKo
      Hi
      If you are using Explicit dynamics then we can not use beam connections (not supported hence greyed out).
      All the best
      Erik
      • kwak dongkyu
        yes im using explicit dynamcis
        so what can i do to solve this.
        which  model is similiar with explicity dynamcis but can use the beam connections?
        (i want to give 100N impact to that top box part and show the devlection through that rod)
    • ErKo
      Hi
      You could try and use Transient Structural.
      All the best
      Erik
  • The topic ‘beam connection disabled’ is closed to new replies.
