March 11, 2024 at 10:45 am
Yi Heng Sin
SubscriberHi,
I am trying to solve an AM LBPF Thermal Structural Simulation on my university's HPC but I can't seem to find any relevant sample batch scripts which I can use for the job submission. Any help would be truly appreciated!
Thanks.Â
March 15, 2024 at 7:51 pm
mrife
Ansys EmployeeHi Yi
You may want to start by asking the HPC system administrator whether the HPC cluster has a job scheduler installed (it should) and whether Ansys RSM is available. RSM takes the place of the user to automate submitting jobs from WB Mechanical to a cluster for solvung. If it is not you can point them to the RSM Guide (in the Ansys Help) and ask if they would set it up. This will make your life much easier.
If the HPC IT, or University IT, refuses to allow RSM to be installed and used then they need to tell you how to submit jobs to the HPC system. There should be a job scheduler available. Â
If the cluster admin needs to know the details of the command, and options, to start a MAPDL batch solve point then to chapters 4.1 and 4.4 of the MAPDL Operations Guide (link below) which has all the command line options then details on batch jobs depending on shell type used.
Mike
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_ope/Hlp_G_OPE3.html
- The topic ‘Batch script for Additive Manufacturing LBPF Thermal Structural Simulation’ is closed to new replies.
5939
1307
