TAGGED: ansys-maxwell-2d, batch-hpc, parallel-computing
May 1, 2025 at 9:21 am
oguz.korman1
SubscriberHello,
I have been trying for some time to run Maxwell2D in batch mode,i.e doing all the preprocessing (drawing, assignments etc...) , solving and postprocerssing in the batch mode. Unfortunately I could not find a way to achieve this either through actxserver or python api. I was wondering if it is somehow possible.
Other problem is about running multiple instances of maxwell2D (either in batch mode or normal mode) but it seems that it is not possible through actxserver because if an instance is already open, second instance command just makes it connect to the first one. This is somewhat frustrating as it does not enable parallel simulations with different geometry and settings. Is there another way to approach this? Is there any stable way of controlling multiple instances ?
All help, discussions are much appreciated.
May 1, 2025 at 9:06 pm
HDLI
Ansys EmployeeHello oguz.korman1,
   I am not sure how you run Maxwell in batch mode, but I suggest using pyaedt. Please see pyaedt document and pyaedt githubÂ
   There are some examples. You can use non-graphic mode to hide instances of Maxwell. Thanks.
HD
3024
971
857
830
777
