November 1, 2024 at 5:34 pm
partha.nakti
SubscriberHello,
I am working on an inverse-designed 2x2 3-dB SWG-based power splitter using Lumopt, aiming for equal power split between the bar and cross ports. To achieve this, I set the figure of merits (FOMs) to 0.5 for each port and used two separate FOM monitors (fom1 and fom2) to track the power distribution. However, I consistently observe that the FOM at the bar port exceeds that at the cross port, leading to an imbalance.Could you advise on whether it’s possible to introduce an additional FOM or constraint to minimize this mismatch? Any guidance on adjusting the optimization setup to achieve a more balanced output would be greatly appreciated.
Thank you very much for your assistance.
November 4, 2024 at 7:08 pm
November 4, 2024 at 8:13 pm
November 4, 2024 at 9:01 pm
Guilin Sun
Ansys Employeeseems good. Please try. Please remember that the actual FOM is olnly one scalar quantity.
November 5, 2024 at 5:25 pm
partha.nakti
SubscriberThank you for your reply. However, the configuration shown in the screenshot I provided in my last message isn’t working. As you mentioned, "the actual FOM is only one scalar quantity." Does this mean that in the part
"target_T_fwd = lambda wl: 0.5 * np.ones(wl.size)"
0.5 cannot be used here, and it must always be a single integer? Could you please elaborate on this?
Thank you.
November 5, 2024 at 6:30 pm
Guilin Sun
Ansys EmployeePlease note the weights are passed to proper variables. You do not need to modify other script. Please visit the example online for more details.
5964
1307
