August 24, 2021 at 4:10 pm
Nicolo
SubscriberHi all
I have a geometry which is basically a serpentine pipe with rectangualar cross-section (see picture below) . It is used for a two-phase flow simulation of co2 and water.
August 25, 2021 at 9:34 amRahul Kumbhar
Ansys EmployeeOnce you create inlet surface on the body, you need to use mesh method. Right click on the geometry>>Insert>>Mesh Method. In Mesh Method, select Multizone Mesh method.
Viewing 1 reply thread- The topic ‘Bad meshing after cutting a surface’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3882
1414
1241
1118
1015
