January 24, 2024 at 10:18 am
Rana Abdo
SubscriberI have a rough surface toplogy that has small peaks and vallys forming the roughness on that surface but there is an error in the surface saying remove or recreate the surface and i want that surface with the same form so how can i fix that error without changing the surface form or topology
January 24, 2024 at 1:30 pm
Devendra Badgujar
Forum ModeratorHello Rana,Â
You might have to delete the surface and recreate it using tools like pull, fill etc. If delecting that surface converts your solid to surface you can use Solidify tools from Repair Tabs to see if that helps.Â
DevendraÂ
- The topic ‘Bad faces’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
1515
1386
1209
