October 27, 2021 at 1:59 pm
barteo
SubscriberHello,
I am trying to simulate a bottle with a hand pump from which glycerin is being discharged. I wanted to model this using the "axisymmetric model". However, the axisymmetric option never worked for me. I checked my mesh, tried a variety of meshes with different skewness, orthogonality, etc. I have also made sure that my symmetry axis is on the x-axis, but the result was always the same.  The simulation crashes even before the first iteration and I am getting the following error (note that when I use planar model, everything works perfectly):
Global Courant Number [Explicit VOF Criteria] : 0.16369
 done.
 iter continuity x-velocity y-velocity  time/iter
    Stabilizing x-momentum to enhance linear solver robustness.
    Stabilizing x-momentum using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: x-momentum    Stabilizing y-momentum to enhance linear solver robustness.
    Stabilizing y-momentum using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: y-momentum    Stabilizing pressure correction to enhance linear solver robustness.
    Stabilizing pressure correction using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: pressure correction    Stabilizing pressure correction to enhance linear solver robustness.
Error at host: floating point exception
The details of my model are as follows:
-Transient, pressure-based, axisymmetric
-VoF - glycerin and air
-Boundary conditions:Â
       -inlet: velocity inlet 0.243 mm/sec
       -outlet: pressure outlet 0 gauge pressure
       -wall-slip boundary conditions everywhere else
Methods: PISO
Controls: Pressure-0.3, density-1, body forces-1, momentum-07
Residuals: 0.001
Initialization: standard - glycerin volume fraction:1
Calculations: Adaptive - Time step size 0.00001, 20000 time steps, 20 iterations/time-step
October 28, 2021 at 11:23 amRob
Forum ModeratorCan you go to the Scale panel (First tab) and post the results?
October 28, 2021 at 6:51 pmOctober 29, 2021 at 11:28 amRob
Forum ModeratorCan you post some images of the mesh and 2d results? Are you running in double precision?
Viewing 3 reply threads- The topic ‘Axisymmetric Problem: Divergence detected in AMG solver?’ is closed to new replies.
5664
1890
1419
1304
