July 6, 2020 at 9:35 am
clarababymangalath
SubscriberI am trying to apply a force in the axial direction so as to see the top body slide over the bottom one and tip down as it crosses the bottom body. But My top body seems to be dragged upwards in spite of applying axial Load. I tried restricting displacement in other directions. This worked but then the tipping of the top body cannot be observed then. Can you suggest me what could be the problem? Its the same problem I am encountering in LS-DYNA as well.
I will try to attach sufficient screenshots
July 6, 2020 at 9:36 am
clarababymangalath
SubscriberIn ANSYS with force load being applied, it generates no result
July 6, 2020 at 3:56 pm
July 7, 2020 at 6:29 am
July 7, 2020 at 6:31 am
clarababymangalath
SubscriberThe picture previously attached was how it deflects on such a load being applied.Â
July 7, 2020 at 6:46 am
clarababymangalath
SubscriberAlso the friction provided at the contact seems to produce no difference. with 0 coefficient of friction or 0.2 coefficient of friction, the results produced are same
July 7, 2020 at 12:13 pm
peteroznewman
SubscriberDo you have gravity turned on to provide the normal force to generate a frictional force?
July 8, 2020 at 4:24 pm
clarababymangalath
SubscriberThanks a lot. I haven't thought of this. I will try this and see
- The topic ‘axial loading and its displacement’ is closed to new replies.
5074
1798
1387
1248
