March 22, 2024 at 10:22 am
March 26, 2024 at 8:17 pm
GLUO
Ansys EmployeeHi,Â
Please right click Results>>Solution data. It shows which setup you are viewing. The opeation type is defined in your setup.
GL
March 27, 2024 at 7:45 am
April 1, 2024 at 2:55 pm
HDLI
Ansys EmployeeHello Atanas Hristov,
   In the bottom of above picture (Design sheet), there is "Note: Performance results are not provided at present for this machine structure. The user will need to modify the source setup in RMxprt-created Maxwell designs.", so RMxprt would not support this design and it is just a geometry model without results.
   Please create Maxwell design to simulate it. With machine type of "generic rotating machine", we have to check and see if it is just a geometry model, because several machine simulations in RMxprt would not support in this option.
HD
- The topic ‘Axial flux PM generator’ is closed to new replies.
5849
