September 24, 2021 at 12:35 pm
dmg15
SubscriberI am trying to perform a modal analysis on a PCB and as boundary condition, I want it to move free as long as it is allowed by the plastic piece which is holding it as can be seen in the following pictures.
September 24, 2021 at 2:52 pmAniket
Forum ModeratorAre you doing a Modal analysis? If yes, Modal analysis is a linear analysis. The contact status is set to open or to close based on initial contact status.
-Aniket
September 25, 2021 at 12:15 pmpeteroznewman
SubscriberAdding to Aniket's comment, in a Modal analysis you can have a No Separation contact because that is linear. That will allow the tab to slide along one face, giving more freedom to the structure compared with gluing the tab to the face. However, you can't have limit stops at each end of the slot the tab sits in because that is a nonlinear behavior.
September 27, 2021 at 7:31 amdmg15
SubscriberThank you so much for both answers!!
Viewing 3 reply threads- The topic ‘Avoid penetration in frictionless contact’ is closed to new replies.
3597
1273
1107
1068
953
