Avoid penetration between two different components
    • matteo.giuffredi
      Good morning everyone, I try to prevent compenetration between the green component and the orange one:
      The green components is in ABS, and the plate is in steel, so the stiffness is different. I try also to change the plate's stiffness behavior in rigid.
      Between the surface I insert two different frictional (I try also frictionless but the result is the same) contacts with Normal Lagrange formulation and I refine the mesh on the contact side (green component) but the final result it's as if the gripper is not affected by the orange plate.
      I try also to increase the time substeps, and I add the large deflection mode.
      How can I to prevent this compenetration?
    • Ashish Khemka
      Please see if the following Ansys Knowledge article helps: How to reduce contact penetration? | Ansys Knowledge
      Ashish Khemka
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
