October 25, 2021 at 8:17 am
piotrkurgan
SubscriberHello,
Have you ever encountered the following error?
October 26, 2021 at 2:53 pmPraneeth
The problem would be because of the lengthy file name for the reports under AEDT results folder which exceeds the allowed file name length in the operating system.
To check this, you can run the same model from any test location with a shorter name.
Please make sure you have shorter names for the project, design and folder names.
All the very best.
Viewing 1 reply thread- The topic ‘Aux thread error: Field file put failed for: ‘Setup1.sf_fld_2’’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4117
1487
1318
1157
