April 12, 2025 at 4:11 pm
s.guha-3
SubscriberHi, i am trying to update multiple design points, i have a dataset of geometry associated to each geometry combination that gets loaded with a script into Ansys discovery. Then i have another script inside ansys static structural that applies materials and boundary conditions, the script however does not run unless i open and manually reconnect it to the model tree. During a design point update it gives an error 'manual intervention needed'. Can someone help in how to trigger the code without having to open ansys mechanical
April 14, 2025 at 12:52 pm
Erik Kostson
Ansys EmployeeHi
Not sure, but seee the below post (especially last part step 3 and 4) on how to use python code objects during design point studies.
https://www.linkedin.com/pulse/script-tip-friday-python-code-object-mechanical-/All the best
Erik
2838
970
851
599
591
