August 23, 2024 at 12:26 pm
thierry.bourdon
SubscriberHello
I am working on correlating results with the NVH Toolkit in ANSYS Workbench 2024R2 and I aim to optimize my numerical model.I am using Mechanical scripting to automate the MAC matrix calculations and to set up loops for optimization. I have successfully created a program that adjusts the geometry thickness and performs the MAC calculation. However, I haven't found a way to automatically export the MAC matrix results to a CSV file without manual intervention.I tried using the recording feature in Mechanical scripting, but no relevant commands appeared on the record page.Is there any command available for exporting, or is there an alternative approach to achieve this?Thank you in advance -
August 26, 2024 at 4:12 pm
dlooman
Ansys EmployeeCould you use *get,my_value,RSTMAC in a commands object to report values in the commands object Details window which could then be checked as output parameters?
August 27, 2024 at 7:25 am
ErKo
Ansys EmployeePerhaps this helps:
https://discuss.ansys.com/discussion/2755/how-to-run-functions-that-are-defined-in-an-act-extension-or-mechanical-add-on-from-a-script
Any questions on that post them under the above post (https://discuss.ansys.com/discussion/2755/how-to-run-functions-that-are-defined-in-an-act-extension-or-mechanical-add-on-from-a-script) -
August 28, 2024 at 2:53 pm
thierry.bourdon
SubscriberHello,
The Get command isn’t working and is returning 0 in the output parameter.
I tried using the script from the link you provided and found the ‘export’ command. However, I couldn’t figure out how to set the file path for the export
Do you have any idea how to use the ExportMAC function ?
nvh_addon = ExtAPI.ExtensionManager.GetExtensionByName(“NVHToolkit”)
nvh_module = nvh_addon.GetModule()
mac_data=nvh_module.ExportMAC-
February 22, 2025 at 1:47 pm
simon.vandercoilden
SubscriberHello,
did you find the solution?
Thanks
February 24, 2025 at 11:52 am
thierry.bourdon
SubscriberHello, Yes !
February 25, 2025 at 2:46 pm
simon.vandercoilden
SubscriberHello, could you share with me how you do that? If possible, could you explain whether, in your optimization loop, you simply observe the MAC matrix or use it for another application? Thanks for your help
5824
