Automating extraction of data at different substeps
    • afm
      I am trying to export deformation, stress, and strain data at different substeps using python in Ansys. This is my current code which exports the selected substep.
      I am trying to create a loop that goes through each of the substeps and exports the data from each substep into a folder based on the data type(deformation, stress, strain).
      # ----------------------- READ ME FIRST -----------------------
      # MAKE SURE THAT THE USER DEFINE RESULTS HAS LOC_DEFX ***FIRST***
      # Second will be LOC_DEFY, third will be LOC_DEFZ
      #input the row number below (for naming)
      row_number = '400'
      # input the file path for where you want the files to export to
      # (do not select 13mm or 18mm folder, stop at skin test folder)
      save_location = r"C:\User\Downloads"
      # No need to edit anything below this point
      counter = 0
      for analysis in ExtAPI.DataModel.Project.Model.Analyses:
          for result in analysis.Solution.Children:
              if result.GetType().Equals(Ansys.ACT.Automation.Mechanical.Results.DeformationResults.TotalDeformation):
                  fileName = "{}\Deformation [D]\{}_D.txt".format(save_location,row_number)
                  result.ExportToTextFile(fileName)
              if result.GetType().Equals(Ansys.ACT.Automation.Mechanical.Results.StrainResults.EquivalentElasticStrainRST):
                  fileName = "{}\Strain\{}_SN.txt".format(save_location,row_number)
              if result.GetType().Equals(Ansys.ACT.Automation.Mechanical.Results.StrainResults.MaximumPrincipalElasticStrain):
                  fileName = "{}\Principle Strain [PS]\{}_PS.txt".format(save_location,row_number)
              if result.GetType().Equals(Ansys.ACT.Automation.Mechanical.Results.StressResults.EquivalentStress):
                  fileName = "{}\Stress [SS]\{}_SS.txt".format(save_location,row_number)
              if result.GetType().Equals(Ansys.ACT.Automation.Mechanical.Results.UserDefinedResult):
                  if counter == 2:
                      fileName = "{}\Z Coordinate of Deformation [ZLOC]\{}_ZLOC.txt".format(save_location,row_number)
                      counter = 3
                  if counter == 1:
                      fileName = "{}\Y Coordinate of Deformation [YLOC]\{}_YLOC.txt".format(save_location,row_number)
                      counter = 2
                  if counter == 0:
                      fileName = "{}\X Coordinate of Deformation [XLOC]\{}_XLOC.txt".format(save_location,row_number)
                      counter = 1
    • Shashidhar Reddy
      Hi
      I request you to post scripting (ACT/python) related queries in the developer forum.
      You can go through following script to loop it through different substeps.
      Using ACT, how can I create a result for each time step and export result to a text file? — Community Forum
      • Store link to solution
        1. solu=ExtAPI.DataModel.Project.Model.Analyses[0].Solution
      • Obtain list of time sets
        1. ResData=ExtAPI.DataModel.Project.Model.Analyses[0].GetResultsData()
        2. DataSets=ResData.ListTimeFreq
      • Loop through data sets
        1. for DataSet in range(len(DataSets)):
      • Define display time
        1. DisplayTime=DataSets[DataSet]
        2. UnitTime='[sec]'
      • Insert result and evaluate
        1. result=solu.AddMaximumPrincipalStress()
        2. result.DisplayTime=Quantity(str(DisplayTime) + UnitTime)
        3. solu.EvaluateAllResults()
      • Export result to text file
        1. FilePath=r”D:\Test\Export”
        2. FileExtension=r”.txt”
        3. result.ExportToTextFile(True,FilePath+str(DisplayTime)+FileExtension)
      Hope it helps.
      Thank you
      Regards
      Shashidhar, PhD
    • afm
      Thank you for your quick reply. When I try this, I receive the error message that "Solution Information" object has no attribute "Display Time". Could you please advise me on why this is occuring?
      Thank you.
